An unknown error occurred in Microsoft Outlook 2010, error code: 0x80070057
Dear,
Recently I try to use Microsoft Outlook 2010. But I face some problem. When I try to create a new profile on Microsoft Outlook 2010 profile. An error occurs. This error displays on my system screen something like in this format, as below:
  • An unknown error occurred, error code: 0x80070057
An unknown error occurred, error code: 0x80070057 I am working a cross-forest immigration exercising Prepare-MoveRequest.ps1; recognize Lifecycle Manager and Active Directory Migration Tool.
Later on windows 7 Personal Computer was transferred to the fresh forest the user reported few issues with his mailbox, Outlook 2010 constant to about the previous Exchange 2003 servers that were stopped working to pass on the user to the fresh Exchange 2010 servers in the fresh forest.
Later on windows 7 Personal Computer was transferred to the fresh forest the user reported a few issues with his mailbox, Outlook 2010 constant to about the previous Exchange 2003 servers that were stopped working to pass on the user to the fresh Exchange 2010 servers in the fresh forest.
I tried to import the PRF into Outlook 2010 by exercising the below authority:
outlook.exe /importprf path C:outlook.prf
At the of import the below error message was practiced:
Why it is happen?
Is it harmful?
How can I fix this problem?
Need a help.
Best Answer by nathaniel jones
Answered By 0 points N/A #113614
Hello Steve90,
Why it has happened?
This is caused by corrupted software, in your case this might be a problem with your email client. Is it harmful?
No, this is not harmful. How can I fix this problem?
See below for the step by step instructions; Resolution Related To: 0x80070057 * Make sure Outbox folder is empty (You may need to disconnect from the Internet if Windows Live Mail says that it's "in use" ) * Delete and recreate mail account (Warning: deleting the account will also delete all messages, please set the customer's expectations) * If able to send emails using webmail, customer will have to contact Microsoft There you are, this should fix the problem.
Answered By 10 points N/A #113615
Hello Steve,
There could be several reasons for getting that error, for instance and antivirus program may be preventing Outlook from sending automatic emails, the address book could be corrupted, or outlook might have failed to autocomplete cache.
To resolve it, you will need to do the following:
  1. First, you will need to clear the Outlook auto-complete cache. You will do that by typing the following command in Windows Explorer: %APPDATA%MicrosoftOutlook. That will open your Outlook Application Data folder, and then you will look for a file called Outlook.NK2 – select it & delete it.
  2. You will need to disable other running programs. You will need to disable the antivirus or firewall program and check if it works.
Hope this helps.
Carl
Answered By 90 points N/A #113616
Hi there,
This problem cause because of two reasons
1st your mailbox located at 2003 server
2nd you are using auto account setup
So to avoid this message create your profile manually, to create profile manually follow these steps;
Step 1 Open the mail control panel
Step 2 click on the show profile
Step 3 Click add in mailbox
Step 4 Enter name for your profile (what you prefer) then click ok
Step 5 in this step you need to Tick “manually Configure server settings or additional server types” and click next
Step 6 Select Microsoft exchange and click next
Step 7 Enter your Exchange server name and verify the username and click next
Step 8 Click Finish
Step 9 Start Outlook
Your problem is solved
Taylor B Campos
Answered By 0 points N/A #196451
Hi.
To resolve your problem verify that you can connect to internet. If you there is no problem with your internet connection, delete all your e-mails in Outlook and open Accounts menu from Tools options. There re-enter your user data ( username and password ). Also make sure that outgoing and incoming server are same. Close Outlook and open it again. Also download Outlook hotfix script from Microsoft and run it on your computer. You can find it here Outlook hotfix tool.
Queen Norman
Answered By 0 points N/A #113617
Hello!
Your problem occurs when both conditions are true:
1.Your mailbox is located on an Exchange 2003 mailbox server.
2.You are using the Auto Account Setup process to create your Outlook 2010 profile.
To fix your problem, Install the August 31, 2010 hot fix package for Outlook 2010
you can download it here: http//support.microsoft.com/default.aspx?scid=kb;en-US;2281463
Hope it helps
Answered By 0 points N/A #196454
To fix this error, all you have to do is changing decimal symbol to . (dot).  To do so:
1.    Open Control Panel, click Clock, Language, and Region, and then click Region and Language.
2.    Click the Formats tab, and then click Additional settings.
3.    In the Decimal symbol field, type . (dot), and then click OK two times.
4.    Restart the computer.
Pamela Conley
Answered By 0 points N/A #113618
Hello Steve90,
As well your solution also you will get huge knowledge about Microsoft Outlook 2010 different kinds of error and solution from this Techyv article. Go this site and enrich your knowledge.
Top 10 Microsoft Outlook 2010 Errors
