No of visitors who read this post:
333
Category:
Google Chrome
Type:
Question
Author:
Maria Jacksonn
I don't know where to post Super user or Webapps.
Here's the situation: I am using Google Chrome Canary. I can't upload any image to Face book. I have tried on Face book, which works perfectly ok. How can I fix this on Chrome?
Edit: I have tried on chrome stable version 17. Same thing happens. I can't upload any image to face book.
Expecting your help.
We all know there are two link to upload photos on Facebook.com. To use 'Add photo/video' link on top is better then another on left. Because it doesn't use flash.
But if we try using photo link from the left panel, it fails to upload because it uses flash.
Now what kind of link you need. Use according to your need.
I think your problem will be solved.
Hathy
Maria Jacksonn
First, you have to check the settings of image showing which should be enable.
Second, your flash player might not working properly You have to download flash palyer new version from this link
then you have to install this.
Best gegards
Brandy Gilmore
