Unable to see images with lights on Adobe Flash 8
How can the images be seen in Adobe Flash Professional 8?  Because I am working with sprites and painting and can make the target background of an image transparent but the light couldn't make it? How can I do that correctly? Help please.
Answered By 10 points N/A #95224
When working with adobe flash professional 8, viewing images may be sometimes problematic. In case you need to the view the documents that you had scanned in adobe flash or any other program, then you will need to set the settings of the website storage panel that you are accessing to unlimited. Say for instance the storage panel has been set to only a GB, then you will only get a single GB stored, and when you pass that limit nothing will show up. The problem seems to happen a lot in the new version of the adobe flash, and therefore you should check and fix that.
Regards
Thompson Locker
