Unable to recover drive encrypted in BitLocker
One of the drives in my system was bitlocker encrypted and I formatted the disc using disk management tool after which I am receiving a blue screen error. I have tried to recover all the partitions using Active@ partition recovery but it is unable to recover the drive that is encrypted. How can I recover the drive?
Answered By 5 points N/A #91208
When you formatted the drives using the disk management tool, did you format the primary hard drive that has the operating system too? In case you did, then you deleted some important system files that are required for the system to work well and hence the blue screen error that you are getting.
What you will need to do to solve that problem is get an installation a CD for the operating system that you had on that computer or the one that you might want to use and then carry out a clean installation of that operating system. A clean installation will remove all the bugs that were created when you formatted the system using the disk management tool and make the computer work well again.
-Experttechyv
