nikemata
Posted on - 09/08/2011
Hello
I recently installed this PDF Editor Software called Infix. After i installed it completely, a message keep showing up like this
Infix.exe – Unable to Locate Component
This application has failed to start because libaspell.dll was not found. Re-installing the application may fix this problem.
I tried to reinstall the software once but I have got no luck.
The message appeared still.
Please give me some advice how to fix this because I really need it for my PDF editing projects.
Unable to locate component error after installing Infix software
Hi
This can be a result of a virus effect. The system component called libaspell.dll might be deleted from the system due to the virus effect or when you were trying to delete some other files it might have been deleted from the system.
Solution
If you have another computer with the same application you go to the folder of the with having the files in the other computer, and copy that file and paste it to yours.
Or Else
Run a fully system scanned on your computer restart and run the program again.
Or Else
You have to follow the instructions which have given in the error message.
Re install the application and try again
