Unable to load software on my Sony Ericsson J10i2 phone
Can someone please help me on loading any software on my mobile phone? I am using Sony Ericsson J10i2 and I need to know if my phone needs a firmware update since I could not load any software. Thanks.
Best Answer by suigeneris
Answered By 0 points N/A #125359
Hello there, you need to download a software called: Sony Ericsson PC Suite.
After downloading, you need to update the software first, and second you need to
backup all your data from your phone to your pc.
Third you will update your phone software synchronizing via PC suite software.
Just remember if you doesn’t make backup all of your phone data will be erased.
Answered By 5 points N/A #125360
Dear,
Each mobile brand has its own software format. You need to install the proper software that supports your mobile. Update of firmware will help you to get better service. Use pc suite for update process. Make sure you have enough data access capacity on internet to complete the update process. Do not shut down your computer during mobile update. Follow your mobile update instruction to have better output.
Thank You.
