Unable to install Windows SBS 2011
When installing Windows SBS 2011 (Small Business Server), I put the folder C: UsersFolderRedirections to F:RedirectedFolders.
Moving this cause the net share to move also in other location.
And when I tried to create new user, folders should be located on the old location.
I could not install SBS 2011 on my default drive.
So I want to know how to move this in other drives such as D: or F:. How can I fix it?
I need help please.
Answered By 0 points N/A #118270
Installation and Initial Configuration:
The Security certificate warnings appear when you run the initial configuration from a client computer by using a firefox or opera browser always.
When you use a firefox or opera browser to set up headless server from a client computer, you will always receive certificate warnings on this.
If you want to stop and prevent these warnings from occurring, perform the following steps easily:
a) From the client computer, you open windows explorer, navigate to \servercertificate, and then you copy the file setup.cer to your desktop.
b) When prompted for credentials, enter the following: Username= administration and Password= Admin ,each time.
c) Open your firefox or opera browser and follow the instructions in your browser's documentation to install the certificate into the browser's trusted certificate authorities list on this.
d) After the certificate is install in it, restart the browser, navigate to  http:/server, and follow the instructions on screen successfully.
