UIExgr.exe – application Error in my laptop
I have a Sony VAIO laptop. I have been using this laptop for more than two years. I didn't face this problem before but now I can't work in my laptop because of this error. I cant run a single program because of this problem. When I click to run a program this error shows in a dialog box.
"UIExgr.exe – application Error the application was unable to start correctly(0xc0000005). Click OK to close the application."
Now what can I do to solve this problem ? Help me.
Best Answer by skyins
Answered By 0 points N/A #87088
There was some possibilities about that error and here is the solution:
  1. Registry error : Try to fix your registry using Registry Mechanic.
  2. Drivers error : Try to fix and update your system driver that may be incompatible or out of date.
  3. Errors in RAM : If you just bought a new RAM, try to unplug them, then try to run  your laptop again.  If the problem persists, you must ask for the RAM to be replaced with a new one.
Hope these solutions help you.
John Rick
