Ubuntu detect wireless networks in my vicinity
In any case depending on if i suspend the session and make it doze and again login then it worked. I attempted it each time that WLAN worked splendidly. Yet still i m unable to intention that startup situation. Every time i boot first I need to suspend it once then just systems are ready. I need to have my ubuntu detect wireless net. It aggravates me every time i reboot/boot my lappy. So please assist out of this situation. Any ideas/help observing this issue could be remarkably treasured.
Answered By 0 points N/A #132669
Hello Jabez,
These kind of problems I suspect have something to do with viruses.
First of all try to upgrade your virus software to the latest version. Then scan your system for viruses.
If the problem remains unsolved, it could have been caused by a software you just installed. Check your recently installed software and uninstall any suspicious software you just installed.
The next step is to upgrade your Operating System hereby upgrading your WLAN driver.
I hope I was able to answer your question.
