Troubleshooting in Solidworks 2011-2012 pupil version
Good day!
 I would like to discuss an issue with you. I encountered it while using Solidworks 2011-2012 pupil version on my Ms windows 7 64 bit PC.
I am using Solidworks for about 6 weeks now in our first season certificate, but now whenever I start Solidworks it demands me to stimulate it.
Maybe, I have triggered something in Solidworks when I try to initiating both on the internet and by e-mail and both provide one concept. Does anyone here know what my issue might be so I can proceed to shield for my group?
It would be much appreciated to get a reply from your end. I included the image below:
Error:
SolidWorks Standard
 Could not initiate the transaction(66,iActTransactionStartFixActiveApp[)/fixActAppActiveReqCreate()errored[8,41013,0]).
Answered By 590495 points N/A #144818
Check again if your version of SolidWorks 2011-2012 supports your computer’s operating system. SolidWorks 2011-2012 supports Windows XP, Windows Vista, and Windows 7 operating systems. Since you are using Windows 7, you really don’t have any incompatibility problem with the program.
You may try doing a clean installation of the program again to restore it to its default configuration and remove possible corrupted files in its installation.
Uninstall SolidWorks 2011-2012 from your machine then restart your system when asked. After booting, check your computer for any possible errors.
Use a disk utility application to check the system. For a much thorough diagnostics on the system, use a disk utility application like Norton SystemWorks, or PC Tools Performance Toolkit. Install the application again after this and see if it works.
If you are still having problems activating your program, you should acquire a new registration code or license key if you haven’t requested it yet. Besides making the program work, it will register the application and activates its main features.
Maybe you are having this activation problem because you are still using the trial version and the trial period has already expired that’s why you need to activate it to further use the application.
