Trouble in running Call of Duty 2.
Hello experts,
I’ve got a problem while I try to run Call of Duty 2 in my Pc. I’ve got an error message, I attached the image below for further understanding of my situation.
I need some help to solve this problem. I would really appreciate any help I get from you guys. Thanks.
Answered By 590495 points N/A #144731
If this is the first time it happened with your game client, try restarting your computer then try it again. If the error is only a fluke then rebooting the system will fix the problem.
If the same thing happened on the next attempt, try running only the game and close any other applications that you may have running. The image you posted shows that there are other applications currently opened while you are running Call of Duty 2.
These other applications currently running in the background add up to the total load of the computer’s memory and maybe one of the reasons why the game doesn’t open.
You may also try reinstalling the game client to have a fresh copy of the game again.
