Hey everyone, I’m having trouble with Daemon Tools v. 3.29. I’ve made an .mdf file using Alcohol which I’m supposed to use in Daemon but when I try to do it an error message appears:
“Invalid ADR field detected.”
Any ideas on what could be the problem here? Thanks very much in advance.
It has nothing to do with your process you are doing everything right. The problem is in the software, there is a bug in Pinnacle's software, and this causes to create corrupt images of their own format. I suggest using DVD Decrypter's and then create DVD mds file feature and then mount the mds file instead this will solve your problem hopefully.
if it does not help try re-installing the tool and recreate the images and try mounting them.
