I have to fix the time of my pc each time I connect to internet. It seems that for someone reasons the time is updated automatically but not the correct local time. So I have changed the local time to the right place but it is no use. Kindly someone tell me what should I do to keep the time stable.
Jeremiah Mai
Time in my pc seems to change each time I connect
Hey Jeremiah mai!
If your system time updates automatically then you have to disable the "Automatic Synchronize with Internet Server" option.
For this purpose you just have to follow these steps.
On the system tray (lower bottom corner), where the time is displayed, double click on it.
That will open the Date and Time properties. There you will see three tabs. Click on the third Tab "Internet Time zone"
After that uncheck the "Automatic Synchronize with Internet Server" option. Click on ok button and you are done.
Now whenever you connect to internet your time will not change.
Thanks
Tunacao caaron
