Is there a way I can convert from PDF to Corel?
Hallo.
I have these free beautiful posters in Adobe PDF formats that I would like to develop further to use in my projects. Unfortunately, this cannot be done in any PDF professional application, or so I guess, and therefore I would like to import them to Corel Draw which I very well know how to use. Is there a way to convert from PDF to Corel Draw? Thanks a bunch.
Best Answer by Darrel R Gonzale
Answered By 0 points N/A #136137
Yes, there are ways to convert PDF files to Coral Draw files. This requires some simple steps and you will be able to get the result. The first thing you need to do is to convert your PDF file to an image file most of websites and programs convert PDF files to JPEG files. After converting PDF files to JPEG files you need to import files in Coral Draw and now you are able to modify the image in Coral Draw Program.
Darrel R Gonzale
Answered By 40 points N/A #136138
Hi dear Greg Charlton,
Thank you for your question.
Yes there is a way by which you can convert the PDF file to Corel draw.
But for this you have to convert the PDF to JPEG then upload it to Corel draw.
To convert any file to any format you can use the following website.
Free online file converter
zamzar Free online file conversion
Neevia Document Converter
Hope you get your answer.
Have a nice day
