I have an HTC Trophy that has HSDPA 7.2 Mbps data speed, Qualcomm MSM8650 Snapdragon chipset, Adreno 200 GPU and Microsoft Windows Phone 7 OS. I was wondering if there's a compatible version of Skype for mobile HTC Trophy? Thanks in advance.
Is there Skype for mobile HTC Trophy?
Hi Hollis,
Yes, there is a Skype Mobile software for your Windows Phone 7. You can easily install this software on your phone by visiting the Official
Windows Phone Download Page.
Alternatively, you can access the Windows Store on your HTC Trophy and search for Skype. That way you can easily download the app directly to your phone.
Regards
Yes, there is a compatible Skype version from your phone.
In order to download the application to your HTC Trophy, you will be required to visit your local Windows Phone website and search for the application from there. You will need to be running the Mango update (7.5) or higher to install the application and the installation directly from the site. This might encounter some issues so they may email an installation link from which you are to access it from your phone to begin the installation.
