Is there a place that I can get bt878 software?
Hello
I found a PCI video capture card that uses brooktree 878 chipset tuners. I do not know what is this, how to install it or a place to get bt878 software. So if someone knows about this process helps me.
Thank you.
Best Answer by LyanaHay
Answered By 0 points N/A #145214
Dear madam,
As I understand, you are looking for drivers for your PCI video capturing device, which is a Brooktree BT878-based card.
You can easily find the drivers by following the link:https://db.toggle.com/free-download/kl174006/Brooktree-BT878.htm
Before installing the drivers, please be sure to secure the card on the PCI slot on the motherboard.
I hope this was helpful.
Kind regards.
Answered By 0 points N/A #145215
Hi Kelseyy Jones,
BT878 software is actually used for to capture videos there are many more software’s available on internet which performs the same job as bt878.
WinDV is one of them by using this software you can actually download this videos to .avi format. But, bt878 actually works really fine in windows XP.
You can get WinDV at http://windv.mourek.cz/
And bt878 at http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/Conexant-BT878-Video-Capture-Driver-50027-for-XP.shtml
Lyana
