Is There Anyother Way To Convert .plt Files to PDF, JPEG etc.?
Hello , Some question about .PLT files , I work in a designing team I would like to convert some of the drawings that are in .PLT to any readable file for the average joe could read. Preferably I would like to convert it into PDF or JPEG so it can be easier to distribute during meeting. Can anybody help me either way its software base or online conversion?
Answered By 5 points N/A #197563
You can convert your PLT files to PDF by opening AutoCad. Select Output and under Printer or Plotter there is Name box. Choose this configuration: Dwg to PDF.pc3. Then select Properties and make adjustments and click OK. Now Create a file name for PDF by selecting location and finally click Save. Also see this link: https://www.coolutils.com/TotalCADConverter It’s a Total Cad Converter, who will convert your PLT files to JPEG format and also to PDF, TIFF, BMP and many other format files.
Williamson Mellisa
