Is there any way to modify a webcam zoom?
Hi there,
I have logitech webcam which has great image quality and great driver support. But the thing is the zoom is not linear as in the zoom goes from 1x to 5x instead of 1x-1.1x-1.2x etc. Can anyone tell me is there any to modify a webcam zoom through an additional software or any alternative ways to do it?
Best Answer by Moses V Patterson
Answered By 30 points N/A #169263
Hi dear,
How are you, i hope you are fine
I have one software for you to zoom your web cam as you desired which is called zoom-webcam software. It is used for zoom your webcam to your requirements. Here is the link of the webcam software to download
http://www.brothersoft.com/downloads/zoom-webcam.html
Clarence K Dwyer
Answered By 10 points N/A #169264
Hello Travis,
There are many programs that are available on the internet that can help you with your problem. I personally recommend:
CamZoomer 2.9
Webcam Monitor 5.05
Ultra Alternative Image Server Combo 11.6
The only thing you need to do is install any of the software and it will be automatically connected to your webcam and you can zoom in or zoom out partially not just from 1x to 5x.
Best,
Moses V Patterson
