Is there any software for doing this ???
Hi All,
I have a Lenovo T61 and I want to know if there is software that could show me how large is my Ram and it could tell me if I still have an extra slot without opening my computer?
Can anyone help me ?
Thanks in advance!
Best Answer by John Handy
Answered By 0 points N/A #100235
Hi Camwynn,
Yes there are Software's that can give you detailed information about your system.
You could try out "Hirens Boot cd", its an all in one software pack that has utility Software's
you can use to read the temperature of your processor, to read your RAM and full
detailed information about your pc status.
You can also check your RAM and usage in your task-bar manager.
Kind regards
John Handy
Answered By 0 points N/A #100237
Hello Camwynn,
There many kind of software that helps you check if you want to know memory information and its slot use. We use this software called CPUZ that has capabilities to determine CPU, Cache, Mainboard, Memory, SPD and Graphics.
You can download it with this URL: http://www.softpedia.com/get/System/System-Info/CPU-Z.shtml#download and size of only 2.15MB.
After installing the CPUZ software open it then click on the SPD tab and Select the slot that you want to know.
Answered By 10 points N/A #100238
Thanks for the help. You guys are great.
There is no question that can't be answered here in Techyv.
Thank again!!
