Is there any iPad screen recorder for iPad 3?
I recently purchased iPad 3 and was wondering if there is any iPad screen recorder available for iPad 3? Any kind of help would be appreciated.
Answered By 0 points N/A #148610
Hello Wirt yule,
Feeling good to hear of your new iPad purchased. And I hope you are now busy with your surfing device. I am going to suggest about screen recorder today. To Quenching your thirsty Epiphan have brought new software for Frame Grabbers and Video recording and using this you can now record high resolution video and capture and record images and streaming video.
For Detail Information:
Epiphan Recorder
Download Screen Recorder
Display recorder Read Details Here:
Display Recorder
Use Airplay for iPad 3 :
Airplay iPad video recording Details
Besides, You will find Display recorder for iPhone and Old iPads(1st generation iPad) and it records portrait mode and works at a lowered resolution
On new iPad go to iPad’s settings > select Display recorder > change video format to MJPEG
Change the rotation to Landscape right
Unless you upload it straight to YouTube, you can’t view or extract the video from the app
I hope this Indication would be helpful…
