No of visitors who read this post: 231
Category: Misc Software
Type: Question
Author: Halleleilani
No votes yet
I need hdd low format tools so that it marks the tracks and sectors on the disk. I am unable to place my data on the hard disk because the starting and ending points of each sector are written onto the platter. So, that is why I need the hdd low format tools.
Comment viewing options
Hi there!
First of all here is the link “http://hard-disk-low-level-format-tool.software.informer.com/download/ “
Go to this link, download and install the Low Formatting Tool 4.1 for your hard disk.
You can also view this video which will give you a tutorial for usage of this tool “http://video.informer.com/s1/win/hard-disk-low-level-format-tool/hard_disk_low.htm “
This HDD Low Level Format utility is free for home use. It can erase and Low-Level Format a SATA, IDE, SAS, SCSI or SSD hard disk drive. It will also work with any USB and FIREWIRE external drive enclosures as well as SD, MMC, Memory Stick and Compact Flash media!
It will also mark the damage sectors which are not useable even after formatting of hdd.
Hope it helps!!
