Test Suit installation error occurred
When I try to install the Suite I ended up with an error message. The error message states that MD5 check failed. I don’t understand the error message and I am not aware of this error message. Do I need to configure anything before installation? Please explain me in detail. Thanks
MD5 check failed for the current file to be staged, the file may be corrupt.
IDS_FILEC:DOCUME~1RODMAU~1LOCALS~1Temp{2FD6FAC4-5DC8-4175-9DAB-4D3FF5E30D53}{0FEA1B66-A7CC-4896-B273-CA977D72BBDD}setup.exe
Answered By 0 points N/A #191022
You probably didn't configure the Test Suite enough. This error would be seen if you have an error in your configuration. Look at your configuration when you see this error. You are either not doing a great job in configuring your settings or you have a mistake or error on what you have configured.
