Tell me more about network wifi monitor?
Hello techyv,
Tell me more about network wifi monitor? I just want to ask if there is a network wifi monitoring system that will record all the possible networking wireless connection activities by the use of software. I just need some additional information for a research.
Expecting some help from you guys.
Best Answer by John Rular
Answered By 0 points N/A #188412
First of all there are many type of low tech methods of doing this. But the most effective way is using Linux and installing ETTERCAP-GTK.
It uses the state of the art WIFI CHIP injection method to find any packet that redirects to other computers.
It also gives statistical details about network usage.
Answered By 5 points N/A #188411
There are a lot of software that allows you to monitor WiFi traffic or the LAN network traffic within your home or office. From small business to large scale business, numerous applications have been designed to suit your needs.
This particular type of software is usually used in commercial internet cafe’s or in secured network offices.
Here are a few of them below:
  (https://www.whatsupgold.com )
    (https://www.tamos.com/products/commwifi/ )
   (http://www.xirrus.com/Products/Wi-Fi-Inspector.aspx)
