Tansee iPhone SMS always waiting problem
I installed Tansee iPhone SMS Transfer software in my Windows XP 64 bit Sp 2 system.  I connected my 8 GB iPhone 3G to my PC and launched the program.  Why is Tansee iPhone SMS Transfer always waiting for the iPhone when my iPhone is already connected?
Answered By 80 points N/A #137288
Step 1 -Check if your phone is properly connected to the computer. If it is connected than follow next step.
Step 2 – Run the application as administrator. Right click on the application icon. Click on Run as administrator.
Step 3 – Uninstall the application and install it back again. If still it doesn't work then follow step 4
Step 4- Install the same application in other computer to check if it is a compatibility issue.
Thank You,
