System Check Adobe Photoshop CS4
Hey guys!
I was trying to install Trial version of PhotoShop CS4, my computer is windows 7. And I got This error message that says "system check" , Any ideas?. I have been searching everywhere to fix this problem. I try many option but does not show any fixes made, it always pop-up all over again. So please help!
Answered By 0 points N/A #82499
i had exactly the same problem. The error that i've had is I just got an Intuos 4 WACOM. I installed the drivers from the disc and all was fine. When i upgraded to the new drivers from the website though it caused a conflict with PS 64 bit and wouldn't load it anymore. I then removed the drivers I installed for the WACOM and then started again installing it from scratch with the drivers on the disc. It is nowall working fine with newest PhotoShop update and old drivers from the disc for the WACOM.
