System Center Virtual Machine Manager 2012 error
This deploy with SCVMM 2012 fails with this error in WinPE. Nothing seems like to work and I did a small research on the Internet. Can anyone help me please to fix this error ? What could be the problem ?
Thank you !
Error: 800b0109, A certificate chain processed, but terminated in a root certificate which is not trusted by the trust provider.
Press SHIFT+F10 to open a command windows. A trace log is available at X:VMMvmmAgentPE.exe.log. This file will be deleted when this machine reboots.
OK
Answered By 0 points N/A #179532
The root certificate should be stored in a trusted repository.
For example in Windows it should be installed in the Trusted Root Certificate repository.
Method 1:
1.  Log on to your computer as an administrator.
2. Click the Start button then select All Programs, Accessories, System Tools, and then click System Restore.
Go to the Start > All programs > Accessories > System Tools > Click System Restore
3. Select "Restore my computer to an earlier time".
4. Select recent system restore point then click next.
5. Restart your computer when it is finished.
Method 2:
1. Download following software
http://cdnrep.reimage.com/rqc/nx/ReimageRepair.exe;
 2) Install > Scan > click Fix error.
4) Restart your computer.
