Hi
I use Windows 7 Beta OS. I find the error message in this morning. And the exciting one that made me laugh. I tried to start explorer for browsing the file system and I get the following error message:
explorer.exe
System call failed. |
Need your help. Thanks in advance.
Hey Rhon petrenko!
There can be possible solutions for this problem. First of all just reboot your computer and you will get rid of this problem.
If the error message persists, then you must install any antivirus program. May be this error is caused by some virus. If you still face the problem then follow these steps. I hope it will help you a lot.
1. On your desktop, when you see this error, press ALT+CTRL+DEL
2. It will open task Manager. Here find and kill the process "explorer.exe"
3. It will make your desktop blank. Then again press ALT+CTRL+DEL.
4. Click on new task and type "explorer.exe".
It will fix the problem.
Thanks
