SyncToy error during Installation occurred
Hi!
I was trying the SyncToy software product on my machine; it’s basically a 64 bit version. But I am facing an error message and requesting for your help.
Setup cannot continue until all system components have been successfully installed.
SyncToy-(x64)-Setup
An error occurred while installing system components for SyncToy (x64). Setup cannot continue until all system components have been successfully installed.
I will very thankful to you.
Best Answer by Drake Vivian
Answered By 40 points N/A #174085
Hi Susan,
Did you check your framework version? Synctoy needs the right framework to complete the installation.
Because SyncToy relies on the components of your framework, it will stop from installing once there is a missing component.
This can be fixed by running the SyncToy full package, or try to meet the framework requirements of your installer.
Thanks
Answered By 30 points N/A #174086
Hi there Susan T Langley,
The error says you don't meet the requirements needed to install the software. The only thing needed to be preinstalled on your computer in order to install and run SyncToys is Microsoft .NET Framework.
To install the Microsoft .NET Framework please visit the official Microsoft webpage, find the suitable version of the Microsoft .NET Framework, download it and run the installation. A set up will take some time, but after it's done you should experience no more difficulties.
Best regards,
Drake Vivian
