Synchronization problem with computer in iPod
I am having synchronization problem in my ipod. When I try to sync the iPod, the computer immediately freezes. The computer doesn't stay frozen after I unplug the iPod. It immediately unfreezes and the cursor is in a different place, f I moved the mouse. In that case the computer is still responding, but it won't bring up iTunes or charge. What is the solution for this problem?
Answered By 0 points N/A #141455
An iPod can only be synced to one iTunes Library at a time (each computer has a different library).This means that, if you want to change the computer you manage your iPod with, it will need to be re-synced to the computer in question.
To do this, connect your iPod to the computer you'd rather manage your iPod on. A popup from iTunes will say something along the lines of "This iPod is currently synced to a different Library. Would you like you sync this iPod to this Library instead?" Click Yes.After that, all the previous information from your other computer's iTunes Library will be erased and replaced with everything that you just synced your iPod with.
