Suggestions for top windows docks 2011
Do windows 7 taskbar functions as a dock? In connection with this, let me also know top windows docks 2011.  I'm running on my PC object dock but it seems not working properly in windows when the program is running.  Object dock seems to be great and even help me organize my icons on the desktop. My problem is that Mozilla Firefox and yahoo messenger won't appear on my taskbar. Icons seems to be unknown although Mozilla and YM really works great.  How to fix this error? Does anyone have a suggestion for top windows docks 2011 software? Thanks a lot for your reply.
Best Answer by Hughes Palmquist
Answered By 0 points N/A #165725
The Windows 7 taskbar looks and works like a dock. The active applications' icons show up within a button, while inactive apps look as icons only. You could 'pin' any app onto the windows 7 taskbar.
Try removing your yahoo messenger and firefox icons from the dock, then drag back the icons of these two apps to your dock, from your program files folder or start menu folders. Check your object dock settings and toggle if your active app is displayed only on the dock only, or on the taskbar, and vice versa.
Pointing you to 7+ Taskbar Tweaker and Winstep Nexus Dock. Take your time check these tools suited for your dock needs.
Answered By 5 points N/A #165726
How are you, hope all is well. There are a number of windows dock software developed to give your computer a pretty and neat background appearance. One such application which I happen to be using right now is fences. It helps you manage your desktop and makes it look beautiful by organizing your applications and folders in docks that you will design and modify to fit your taste. It also hides your icons when not in use.works.jpg
This is a sample of how the application looks like.
http://www.afterdawn.com/software/desktop/misc_desktop_tools/stardock_fences.cfm This URL will direct you to the site where you can download the application for free.
