Stuck on safe mode Please help!
Asked By 110 points N/A Posted on -
Please help! My computer goes to safe mode every time I restart my computer. The only way I can boot it to normal mode is by going Advance Boot Options and choose normal mode. Any ideas to fix this? I am using Windows XP SP3 Home Edition.
Best Answer by Lonnie Pella
Answered By 0 points N/A #88246
If you don't mind programs that could be lost, use system restore and choose a date that you know it was booting in normal mode properly.
Answered By 110 points N/A #88249
There's no restore checkpoint. All dates are grayed out.
Answered By 0 points N/A #88251
Start > Run > type "msconfig" > Ok. Click "Boot.ini" tab > Uncheck "/SAFEBOOT". Restart the computer and it will be in normal mode.
Answered By 110 points N/A #88253
Unchecking "/SAFEBOOT" worked. Thank you!
Answered By 0 points N/A #88254
Excellent. By the way, this is how it looks in the Microsoft system configuration window.
**Note: /SAFEBOOT will be unchecked.
System Configuration Utility
Answered By 110 points N/A #88255
Nice post! Very helpful visual aid. Thanks again.
