Starting up an .exe file
Hey everyone,
I’m having trouble figuring out how to run this uniq.exe file. I have Windows 7 Pro OS and I never had a problem like this before. The error message that comes out when I start the program is:
Error occurred
Access violation at address 007F3B7A in module ‘uniQ.exe’. Read of address 00003508
OK                                                 Details
Send this error via Internet                                                         Copy to Clipboard
If someone can help with this please provide any info you’ve got.
Thanks so much.
Best Answer by lee hung
Answered By 10 points N/A #92066
Hi Daniel,
I suggest that you try to download another (Latest) of the windows messenger live and see if it works for you. This problem should not be occurring unless you are having problems with the internet connection or may be there are some important files missing in the download.
For more information, try checking out the link below: Download Link
Hope this helps
Lee Hung.
Answered By 10 points N/A #92068
Sorry, the right post is this one:
Hi Daniel,
I suggest that you try downloading another (Latest) of the windows messenger live and see if it works for you. This problem should not be occurring unless you are having problems with internet connection or may be there are some important files missing in the download.
https://www.microsoft.com/en-in/download/details.aspx?id=31330
Hope this helps.
Lee Hung.
