Speeding Corel Paint 2015 watercolor brush up
Asked By 100 points N/A Posted on -
How can I speed up Corel Paint 2015 Real watercolor brushes from slow things down? I have been enjoying the Corel Paint 2015 prog that I install on my system, but the water color brushes are some times too slow for my liking. I taught it was the installation, but after system maintenance, the prog is still slow. What could be responsible for this slow down?
Answered By 0 points N/A #189393
Generally, brushes are stored temporarily into memory when you open Corel Painter, so adding more brushes needs more memory capacity. If the memory threshold is already near at its peak, organizing new brushes into secondary libraries is advisable. Likewise, limiting the number of items in each library. So, if you would now want to use different brush set, just switch libraries. By adding libraries or relocating brushes that evade direct use of RAM helps Corel Painter be more efficient with memory usage, and makes it more convenient to find a particular item.
