Sony PC Companion problem there is no software available for phone
Does any of you guys knows if Sony have some problem with their servers? I cannot run the updater because of this error. It has been a long time since I last updated my apps on smartphone.
Thanks!
Sony PC Companion
Problem:
There is no software available for your phone / tablet
Details:
Sony Update Engine doesn’t have software available for your phone / tablet.
Troubleshooting:
Please try again later.
If you still encounter problems, please report issues to Sony Mobile (opens in a new window) and
provide the error above.
OK
Answered By 590495 points N/A #187965
I don’t see this as an issue because it is only normal for a handset to still not have a software update due to the fact that sometimes it is or the software update is based on the handset model because of proprietary operating system. Your phone software will automatically alert you of new software or firmware update once you connect your handset to your computer and opening the application.
If you don’t see an update or it says that it doesn’t have an available software update for your device, try some other time. Since you are using PC Companion from Sony, this software includes the Sony Xperia Transfer tool. It is a utility that you can use to transfer the contents of your old handset to your new Sony Xperia Smartphone.
The Sony PC Companion software requires Windows XP Service Pack 3 x86 only, Windows Vista, Windows 7, Windows 8, or Windows 8.1 both x86 and x64. This program doesn’t work on Windows RT. If you wish to download it again, visit Sony PC Companion. If you are a Mac user, you can use Sony Bridge for Mac instead.
It requires Mac OS X 10.6 Snow Leopard and higher. You also need to have iTunes 7 and up, iPhoto 8 and up, and Java Runtime Environment 6 and higher.
