No of visitors who read this post:
522
Category:
MultiMedia Applications
Type:
Question
Author:
Abraham adams
The time I play my favorite game namely Soldier Front, an error message breaks down the process and gets me out of the game. I’m merely facing this particular issue with Soldier Front but not with any other games. I am in great need of help and support. Following is the screenshot of error message I’m facing.
Error:
Toocan IPC Window:Windows-Application Error
The instruction at "0x7c342f30" referenced memory at "0x7e4311d1".The memory could not be "written".
Click on OK to terminate the program
This error is usually caused when the OS allocates memory to a program that is originally not dedicated to that program; normally, a program has access to a range of memory that has been already assigned to it. Now, if this program try to access memory that is not assigned to it, a similar error message is raised.
But what will causes a program to access a memory that is not assigned to it, unfortunately, this can be caused by a large variety of problems.
But you can still try to uninstall the game, and remove all the associated folders, search in you computer for any folder that is linked to your program and remove it.
Once removed, try to re-install the game.
Hope this will solve your problem.
Thank you
