Softwares similar to that of Abylon Basic 7
Hi Techyv Guys, I would like to have the name of the few softwares similar to that of Abylon Basic 7, that ensures the security of confidential data through encryption methods. If you have used similar software, please leave your reviews on that. Please do the needful as I am in a research on similar softwares.
Answered By 85 points N/A #135114
Hello
A program that you may want to try is Kruptos 2 Professional. It has 256bit encryption. Without the password the files can not be viewed in any way. When you finished with the files you are working on the files get encrypted again automatically.
Another option is FolderLock. It also has 256 bit encryption. Your files can be automatically backed uponline. All files are encrypted. You can create .EXE files that will extract but only with the password.
