Software or Application to Speedy PC performance
Hello Friends,
I am using Windows 7 64-bit Operating Systems with 2 GB RAM, recently my computer’s performance seem to be very slow. Please do the needful for sending tips for improving the PC Speed or suggest me a best software or application that will speedy PC performance.
Thanks and Regards,
Zack Lee
Best Answer by Luke N Marks
Answered By 0 points N/A #132451
Dear Zack Lee,
SpeedUpMyPC 2013 will be a great solution for improving the speed of your PC.
  • It is a famous application for a long time on the speed issue.
  • It will scan your computer in order to find the reasons of slowdown issues as like as invalid registry entries and unused processes etc.
  • Then it will fix the errors and improve the performance of your PC.
    Download SpeedUpMyPC 2013 as quickly as possible and enjoy the performance of your speedy PC.
Answered By 0 points N/A #132453
Hi Zack, to boost Windows 7 to its maximum possible performance there are plenty of guides for you to follow to experience some performance improvement.  Hit this link http://www.computingunleashed.com/speed-up-windows-7-ultimate-guide-to.html and you will find easy guidelines that will surely help you with your problem.  Trying some of those tips will surely increase the performance level of your computer.
Answered By 85 points N/A #132452
Hello.
  1. Speed issues can be caused by a number of things.
  2. First clean out your computer with compressed air by blowing out all the dust.
  3. It could be hardware that is failing. Such as the CPU or the Hard drives. It would be advisable to back up all your data onto disc.
  4. It could be a virus or malware. Download Avast and Malwarebytes ​Crushes malware. and install both programs and run them.
  5. Once the other scans have run repair your windows. Here are the instructions on how to do this.
