Software that is not registered, I want to use long time
I have many software that are not registered but I want to use for long time. But when the trial period is expired, then these software are not working until I reinstall windows. I want to use them in same windows. Any one can get me out of this problem.
Best Answer by darrens
Answered By 0 points N/A #114402
I am providing you 2 solutions.
Solution 1
You can use the software that increases the track phase which you necessary and my human change you equivalent below where you can download this software.
Download Source 1
Download Source 2
Solution 2
I was Facing difficulty when I IDM was suspire and I installed again but corresponding recorded job was comfort. Prime  Uninstall the want software and then type REGEDIT in your run command. Then  HKey Anesthetic Machine -> software, Hkey Local User -> software, from both take the complete folder which software you necessary to remove. The re install software I trust you will give me a fix to this problem.
Answered By 10 points N/A #114403
Hello there,
Morally I don’t support this kind of piracy work, but this is fun sometimes.
As you told that you are willing to uninstall that and reinstall it but not the whole window. So simple answer is to clean the registry and find out every single trace that software kept into the system. Delete all of those from your computer and reinstall it.
For some easy way install an uninstaller like:
http://www.softpedia.com/get/Tweak/Uninstallers/Revo-Uninstaller.shtml
Also for cleaning the registry manually, you can use winaso or some other registry cleaner as you like or familiar with.
Thank you,
Riley weaver
