Software installation problem in windows 2000
I have a operating system Windows 2000 so after downloading some software like yahoo messenger, Gtalk, WinZip does not installed, have any process for installing it.
I need the suggestion so that I can install it.
Answered By 5 points N/A #127278
This is the better option to change this operating system and use windows XP professional if possible. However I am giving two solutions for this problem. I hope it will work.
First advise is to use old versions of yahoo messenger, Gtalk, winzip etc. may be you downloaded latest versions of yahoo messenger, Gtalk, winzip. Windows 2000 have no direct support for new software. So use old version of them.
Other option is you can change capability option for run this software in windows 2000. For this install them and go installation .exe file and right click on it. Go properties then capability tab and here in capability mode option uncheck the box and change capability with windows 98/ windows Me.
