Single sign on active directory
Asked By 130 points N/A Posted on -
I run the window xp for the supportive environment, but as you that window xp is very old and have some issues I use window xp single sign on active directory, but as I transfer from window xp to window 7 then it gives lots of errors on single sign on. Is single sign on active directory is not compatible with the window 7.
Answered By 0 points N/A #185227
Please check the browser compatibility and check that you are using the latest browser. Whereas there is no problem with single sign on active directory as it has all the same function as on the other windows. So it might be the problem with the configuration so please also check the following.
GO to the setting.
Check the security policies.
Check the Network Security.
Check all the configuration in the internet option. There will be the problem for one of them. So check them and do the configuration manually and it will solve the problem. And your problem will be solved.
