From internet, I have downloaded the Shutdown timer's portable edition.
When I try to start it, it gives a dialog box said Shutdown timer has encouraged a problem and needs to close. We are sorry for the inconvenience.
And this similar problem is with a number of particular software's also.
I need to solve this problem. Need a solution. Please help.
Error: Shutdown Timer has encountered a problem and needs to close.
Hello There,
Buddy the reason of your problem started in having a problem in installing or uninstalling the program. Having a premature install or uninstall with this program will cause that error. The best way to fix your problem is to download the shutdowntimer.exe fix tool.
Heres the link for the fix tool: http://www.fixdllexe.com/Product.php
Hope i did help you have a nice day.
Luker Malcom
