Sharp high resolution IGZO LCDs
Sharp rolls out high resolution IGZO LCDs, what is the difference of this LCD compared to crystal LED?
The word IGZO stands for Indium Gallium Zinc Oxide. It is a semiconducting material developed by both Semiconductor Energy Laboratories and Sharp Corporation. It is a substitute for amorphous silicon for the active layer in an LCD screen and is also used as the channel for translucent thin-film transistor. It has a forty times higher electron mobility compared to the usual amorphous silicon.
With this, it allows greatly higher speed reaction for screen, and or smaller pixels for screen resolutions higher than HDTV. Just early this year, Sharp unveiled its 32-inch 4K resolution IGZO LCD monitor at the 2013 International CES in Las Vegas. The company described that using the IGZO technology produces more natural image with better presence. It produces just about double the resolution of present LCDs. I also learned that Apple is planning on adopting the IGZO technology as the LCD screen for the next iPhone.
