Share point error opening pages online
While I was opening pages in SharePoint online this problem occurs. It worked just fine until now and I cannot manage this. Any solution for my problem please ? Why is not working right now when I needed the most ?
Thank you !
Error
An unexpected error has occurred.
Troubleshoot with Microsoft SharePoint Foundation.
Correlation ID : 30C92a9c-9a94-70db-od25-ec9aff3a06f7
Date and Time : 01/07/2013 06:36
Answered By 590495 points N/A #180354
This issue can happen if you are using SLK. If you want to check the log files created, if you are using Microsoft SharePoint 2010, you can find the log files in “C:Program FilesCommon FilesMicrosoft SharedWeb Server Extensions14Logs”. If you are using Microsoft SharePoint 2007, you can find the log files in “C:Program FilesCommon FilesMicrosoft SharedWeb Server Extensions12Logs”.
To look for the log file, find the date indicated in the error message, for example “01/07/2013 06:22:36”. Since the log files are not in binary format, you can open it using Notepad or other text editor application. One user was able to fix it by completely uninstalling SLK and then installing it back. It worked the second time.
