Security alerts in Microsoft® Outlook
Hi Mates,
Security alerts in Microsoft® Outlook. Its annoying when i have an internal application or a script try sending emails from my outlook i get the security popup asking e to accept it.
Outlook 2007 and 2010 both i have this issue.
Is there any way we can suppress.?
Thank you
Answered By 5 points N/A #119341
The Advanced Security for Out look itself is the tool for blocking violators or allowing an access to your e-mails address that is stored in your MS Outlook.
When you set an action you can specify a permanent handler to a certain program. It has two drawbacks in which it allows your to track the source of the violator, the other is the repeatedly displayed warning because some of these applications are already developed before this system security is implemented.
You can just choose to “allow access” or “block access” or the “call default handler” permanently in order to stop the repeatedly security pop-up.
