Secure Your Internet Connection: How To Lock Your Wi-Fi
Hi. I am recently got a Wi-Fi connection set up in my home. However, I don’t want others to be able to use it else it will slow down its speed. In addition, I want to make the browsing sessions safe. How to lock your Wi-Fi? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #85080
Hi. To learn how to lock your Wi-Fi, first open the web browser you use and then type the IP address of your router and press enter after doing the needful. Type the default name of your router and the password when the window opens and then click on enter. After this, browse to the wireless security settings or network security settings and then change your security in it. Jot down the security passphrase for future use. The settings should be saved next and then the browser should be closed. You could also first log in to your account and enter the IP address of your device. Next, you can click on the primary network option from under the Wireless tab following which the wireless protected access should be enabled. The password should then be typed for the Wi-Fi network and confirm it by re-typing it. Make sure that the password entered is strong and cannot be breached easily.
Hope we helped.
