No of visitors who read this post: 212
Category: Misc Software
Type: Question
No votes yet
This is the common scare messages. Also this scareware shows fake errors about one of the active process as well as then provides a fake answer to fix the error. Please help me.
mbam.exe
mbam.exe has encountered a problem at address 0x45BE49.
We are sorry for the inconvenience.
If you see this error again, operational information can be irrevocably lost.
        Close
Address space conflict
Warning! Access conflict detected
An unidentified program is trying to access system process address space
Process Name:               mbam.exe
Location:                        C:\Program Files\...\mbam.exe
Company Name:             Malwarebytes Corporation
Owner's Name:               MALWAREHELP/malwarehelp.org
Internal Name:                mbam
Enable (Recommended)
This option blocks any unauthorized process which intrude into
the address space of your Operating System.
Disable (Not recommended)
Try not to use this option. Ignoring suspicious processes may
hamper system performance or cause your Operating Syatem to
crash.
                         Accept               Cancel
Thanks a lot.
Comment viewing options
hello there buddy. the first thing you should do is turn of all the start up services in your msconfig.
to do this simply open the run command, and type msconfig
on msconfig go for the startup tab. and dis able all. and restart your computer. at first this will help you stop the problem because im sure that the specified program will not run. but our main goal is to remove that program.
after the restart. go to control panel and look for the Mbam program and uninstall it. if you are not sure where it is just right click the desktop icon of Mbam. then properties and find target.
hope this helps you solve your problem. have a nice day.
