Sand boxie error opening the program
Hi experts,
I got this error from Sandboxie and I don’t know why it cannot start properly. I made the proper settings and it runs with compatibility. Any solution for my error ? I did something wrong ? Please help me to prevent this kind of error appear in the future.
Thank you !
SandboxieDcomLaunch.exe – application error
The application was unable to start correctly (0xc0000005). Click OK to close the application.
Answered By 590495 points N/A #179031
If you are using Sandboxie on Windows Vista or Windows 7 then it could be a privilege issue or it could also be a compatibility problem if you happen to be using an old version of the program. Check your current version of Sandboxie if it supports your operating system. You can find the system requirements of the program normally in a readme file included in the installation.
Check the installation folder for the file and other documentations. Try starting Sandboxie as administrator. Right-click Sandboxie on your desktop then point to “Run as” and then select Administrator. If this works and Sandboxie opens successfully then set it to always open as administrator to fix the issue. Right-click Sandboxie then select Properties. Select Compatibility tab then check “Run this program as an administrator” and then click OK.
From now on, every time you start Sandboxie, it is always started as administrator or with administrative privileges. Also, check if you are using the latest version. If not, download and install Sandboxie 4.12. It requires Windows XP Service Pack 3, Windows Vista, Windows 7, Windows 8, and Windows 8.1 both x86 and x64.
