Hi! I have just heard about the latest release of the roaming feature by Samsung optimized for its Samsung Galaxy S3 model. Can anyone tell me what is this roaming feature is going to be used for in a country like India? Thanks for any logical answer.
Hi there,
Please be advised that global roaming won't be possible immediately. But if your network is Verizon, you will be able to roam using 2G and 3G networks in other countries but software update is needed so you need to wait for it. Once you are on roaming, you will be able to talk using your Samsung Galaxy S3 or you will be able to use your phone when travelling on different countries. You just have to wait for the OTA update to be available, and once available, you may update your phone in order to turn global roaming on.
