No of visitors who read this post: 205
Category: C++
Type: Question
No votes yet
Hello
Runtime error happens during the implementation of a program. Runtime error messages point to the bugs in the program or troubles that the designers had expected but could act nothing
Error:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: C:\Program Files\Internet Explorer\iexplorer.exe
This aplication has requested the Runtime to terminate it in an unusual way. Please contact the application's support team for more information.
Please help me to solve this. Thanks a lot.
Comment viewing options
Joseph hope the following solution helps you in fixing the issue for which you are facing the problem of occuring Ruuntime Error.
Runtime errors are the errors that occur dynamically and may be caused not due to program it may be caused due to library files .
As seeing your error i can say that the path might not be set in correct way and try to check and fix the correct path which needs to be ehanced in correct manner.
The files from library may be missing due to that also there is a mighty chance that results in causing of Runtime Error Explicitly.
Try to Edit the application by installing again with a fresh copy by removing the older one completely by rebooting the system after successsful uninstallation.
Thank you.
