Running MP4 videos in Nokia 3310
Asked By 7060 points N/A Posted on -
I have a Nokia 3310 mobile phone (Hungry made). Last days, I lost its software due to autorun virus. I upgrade its software from PC Suit. But, now I am facing one problem with it.
The problem is that my mobile software doesn't support MP4 (format) videos (even mobile MP4).
The message " unsupported file" come on the screen while opening the file.
Is anybody describe the way, How can i run the MP4 videos on my mobile?
Thanks
Best Answer by David lam
Answered By 0 points N/A #80031
When a smart phone creates problem the best ways is just flash phone memory and reinstall the phone software to work phone properly and run mp4 videos on Nokia 3110. Sometime update with Nokia pc sweet does not works properly.
Though there is another way to run mp4 videos in Nokia 3110. Download some software of mp4 players in Nokia 3110 can do this job. Some software’s have that kind of capability to run mp4 videos. This software can be found in many mobile websites.
  Most popular of them is www.getjar.com
It’s a website where all necessary software for Nokia 3110 can be found.
Answered By 15 points N/A #80033
The operating system that you installed does not have a player that supports MP4 video files, then you will need to do the following:
  • You will need to download an MP4 player from the internet and install it on your computer. Make sure that you download an MP4 player that is supported by your phone.  You can also download the application from your phone if you can be able to connect to the internet with it right now, since it is a Nokia phone you can get the application from the ovi store or getjar.
  • You can also choose to convert the video files you want to play on the phone into a format that  the mobile phone be able to support.
-Clair Charles
